All right this is a 10" Cerwin Vega Stroker sub that I want to make an enclosure for. I was gonna sell it but thought what the heck I will go ahead and try it for home theatre. Here are the T/S parameters:
Fs: 36hz
Qts: .72
Qms: 10.2
Qes: .775
Vas: .566ft3
Xmax 29mm
Revc 2 x 1.6ohm
It is a DVC 2ohm sub that handles 2000 watts RMS. I gave it a shot with WinISD beta and about 3.8ft3 tuned @ 20hz looks pretty good for this sub I thought, but I am definitely not an expert.... so any recommendations would be awesome from you experienced guys. I will start out powering it with an O Audio 500 watt bash but might jump up to a Behringer EP2500 at some point.
Are you sure the Vas is correct???
That looks extremely low, even for a 10" woofer!
I modeled the sub. All in all, there are much better options out there. The response starts at -3db at 85hz, peaks near +.25db at around 46hz, then dips to -1.91db at 24hz, it then goes up to -.94db at 20hz and then to -3db at 18hz The response is very peaked near tuning.
Enclosure size offering best response is 3.5ft^3 tuned to 20hz with a 3.5" x 15" vent 93.70" in length. That is the smallest vent that keeps the vent mach within allowable limits.
This also figures using an infrasonic filter at 18hz 2nd order (minimum) and a low pass filter at 80hz 2nd order (minimum).
