L
Lilmo6868
Would like to hear y'all's recommendations on some good quiet cooling fans or cooling fan system. what is the best route to go ? AVR is getting a little warm but I don't want to take any chances. Heat kills over time, this i know. Lol..
ski2xblack
ski2xblack
Home-brew using a quiet computer fan wired up to a variable voltage wall wart supply, plugged into the auc ac plug on the rear of the AVR. Parts cost about $15 from digikey, mouser, etc.
agarwalro
agarwalro
@Lilmo6868
AC Infinity AIRCOM S9, Quiet Cooling Fan System 17" for Receivers, Amps, DVR, AV Cabinet Components https://www.amazon.com/dp/B01LVUWOBX/ref=cm_sw_r_cp_api_Hud0zb3P11KMR
That seems way overkill, no need to spend $70.
+1. This is the way to go.
I've had this one running non stop for over a year. Costs $15. Comes plug and play ready with a female USB built into the cable so that a port is not blocked.
https://www.amazon.com/dp/B00G05A2MU
