This is the most obvious advancement in the history of audio. SAS's (Super Awesome Speakers) Model 1 has five patents pending on extreme developements in audiophile grade speaker system world. It's unique design enables you the sucker, I mean customer to get the best audio system in the world.
The Model 1 has one of the most advanced crossover networks available. By using the minimum amount of resistors and other electronic devices our x-overs provide with an amazing soundstage using Parallel United Kinetic Energy (P.U.K.E.) patent pending. The x-over is attached to the Model 1's side mounted spring clip terminals (patent pending)
These links give you a close look at the internal workings of this magnificent speaker.
http://i127.photobucket.com/albums/p145/Seth_L/2006_1215Image0004.jpg
http://i127.photobucket.com/albums/p145/Seth_L/2006_1215Image0005.jpg
http://i127.photobucket.com/albums/p145/Seth_L/2006_1215Image0007.jpg
http://i127.photobucket.com/albums/p145/Seth_L/2006_1215Image0008.jpg
Next the port design, it is flawless. Using anti-resonant materials and adhesives you get absolutely no port noise, accept all the chudding of coarse.
The enclosure of the Model 1 uses the same anti-resonance technology and combine that will ultra light-weight material you can experiance great sound without a heavy enclosure, very good for WAF.
It has a 4" subwoofer that has an excursion of nearly 1 cm, which easily destroys two 18" woofers.
Here are the specs:
Power handling- 237.2 watts RMS
Impedance- 1 ohm nominal
Efficiency- 105 dB @1 watt +/- 100 dB
Frequency responce- 10hz-100Khz
Weight- 2.48 lbs.
Visit:
www.superas.com
