stratman
stratman
Anyone looking for a small space? Perhaps an office or a guest room? These are a bit pricey, but if you can spare the change they look like they're very functional. It'll make a decent pool cabana or the ULTIMATE MAN CAVE, your private, micro HomeTheater, you know, when the kids and the wife are driving you nuts.
http://www.kithaus.com/
Davemcc
Davemcc
I'd like something exactly like that in my back yard. They look good, but you are right about being pricey. They're about 3x what I would have guessed about the cost.
stratman
stratman
Hey Mr. D,
Pricey they are, but it gives you a good idea what can be done with a small space. Any adventurous, tool savvy audioholic can tackle this.
Davemcc
Davemcc
So far, my yard is primarily vacant space gone to waste. I rarely so much as look out back. But some kind of lounging shack is on the wish list for whenever I get around to doing something back there. You see, I'm an indoor cat and this is just the type of thing to bring the indoors outdoors.
Shadow_Ferret
Shadow_Ferret
That would BE my back yard.
"Sorry kids, you're going to have to play in the street now. I have my clubhouse in back now."
jinjuku
jinjuku
Moderator
Jeez, $39,900 for 187 Sq foot? That is $213/sq foot. I could build an 12X24 for around $30,000 with mechanicals.... (plumbing and electrical).
stratman
stratman
Yup it's expensive, but to give them some credit, the materials they use are super-premium, anodized aluminum members, exotic wood facade, I believe the glass might be impact resistant, none the less it's pricey. With a bit of imagination, power tools and some elbow grease it's not a hard project to tackle, I'm guessing with a budget of $10,000.00 I could duplicate a similar structure 12x12.
