Converting Apple Music files
U
umanikhat
Hi, I’ve been using Apple Music for a while now and recently started planning on getting a dap to listen to music on the go. I was wondering how to download files on iTunes in a different format(such as flac) and move it on an sd card and into a dap and play it from there. I came across something called note burner that converts the files but I am not sure if https://omegle.onl/ it will work or if I would just use Apple Music on the dap(perhaps switch to tidal too) Any recommendations or experiences with software that could convert and download files from itunes? Thank you
