Vancouver said:
So if the HDTV and EDTV were the same price....which would you buy and why?
I would buy the TV that looks best from the distance I will be away from the screen - which is what every buyer should do.
People put to much focus on 'resolution' as a end-all be-all of what a good HD capable television is. The reality is that a good 853x480 display can look better than a poor 1366x768 display. Screen door is not a function of pixel count, but of how large the gap is between pixels. For example, if you have 4 pixels covering 4 square inches and each pixel is barely under an inch square, then there is a very small screen door affect. But, if you have 16 pixels (4 times as many!) covering the same area, but each pixel is only 1/16 square inches - then half the resolution is 'screen door' effect. So, it is easy to see how screen door is not a function of the number of pixels, but the size and distance between pixels.
If price were the same, image appeared the same from my viewing distance, and image quality looked the same, then I would go with the HD unit just because I could hook my PC up to it and run my PC at 1366x768 native and have it look really, really good.
But price is basically never the same (except I got my 50" plasma for $3200) and you have to decide whether the extra $$$ is worth it.
