Considering APPJ EL84+12AX7 + AudioSource AMP-102 for setup
theportmeister
hello guys, i'm planning to buy a semi-serious setup pretty soon but like oh so many, i'm on a tight budget.
i wanted to know if an amp like the APPJ PA0901A can be used as a tube "preamp" for a much larger and powerful AudioSource AMP-102.
i came to this combo because i was looking for something that would bring in the tube sound and headroom whilst having the benefit of the much more powerful transparent amp that AudiosSurce offers.
i already have my speakers which are a pair of bipolar, Definitive BP6B's rated upwards to 30Khz, currently being run from an all-in-one stero system which i wont even bother to mention.
i plan to use the appj with my Grado SR125i's but would like to pipe the sound out from the tube amp to my larger solid amp and speaker setup if possible.
can this be done?
thanks in advance.
Appj:http://www.amazon.com/APPJ-PA0901A-Amplifier-Original-miniwatt/dp/B00APC0WWE/ref=sr_1_2?ie=UTF8&qid=1363543511&sr=8-2&keywords=appj
Audiosource AMP-102:http://www.amazon.com/AudioSource-50-Watt-Stereo-150-Watt-Amplifier/dp/B0013CZX0G/ref=sr_1_1?ie=UTF8&qid=1363543502&sr=8-1&keywords=audiosource+amp-102
Speakers:http://www.amazon.com/Definitive-Technology-Tower-Loudspeaker-Single/dp/B000TD8XG6
Headphones:http://www.amazon.com/Grado-Prestige-Series-SR125i-Headphones/dp/B0006GCCWW/ref=sr_1_1?ie=UTF8&qid=1363543553&sr=8-1&keywords=grado+sr125i
theportmeister
what if I employ attenuation from one amp to the other?
Won't work.
However if money is tight avoid tubes. A circuit built round a fifty cent op amp chip will beat the pants of ANY tube preamp.
Single ended tube amps like the ones you suggest sound absolutely horrid and have more distortion than signal.
You get twerps like those on 6 Moons audio waxing eloquent and not one of them would know a grid, from an anode or cathode.
This whole fad is just hokum and bunkum.
theportmeister
you know what, im scrapping this whole tube idea.
that Onkyo has everything i need including pre-out for a secondary 50w power amp i will be employing for my patio speakers.
i had walked away from AV-Receivers because a lot of them have more channels than i will ever need and i don't know which is better, this convers my needs at a good price.
That was a very smart decision.
However you need to be aware, that that unit has no bass management. So your main speakers will be full range and you can add a sub to supplement them.
There is not HDMI connectivity, only low grade composite connections, which are no longer useful.
We really do not a good 2.1 channel pro/pro or receiver with bass management and a selection of HDMI inputs and outputs. Such I thing does not exist as far as I can tell.
So for AV use you are now forced to buy multichannel devices with complex set up whether you like it or not. This is bad. The vast majority of rooms and systems would be better off with 2.1 channel in my view, if there was a simple unit available like I described.
I argued the point with someone very high up the food chain in Marantz last week. He says there is no demand, but I told him that he does not realize how many customers he is turning away. This is a very bad state of affairs especially for classical orientated listeners. They seem to be condemned to ipod docks now, and they are not happy.
I have one AV room, and two systems that are two channel plus sub.
Until recently two of the systems were vintage two channel work arounds. How ever my wife could just not get the hang of the one in our Eagan home, and hated all the wires.
So this was the end result.
I ended having to put in a huge multichannel pre/pro. My wife is pleased however, and finds it very easy to use, and she is happy.
However a neat little 2.1 pre/pro would be much better!
