Connection to house system humming noise
Mitd
When I connect my mixer to the house system (bose jukebox system) I get a low hum from their speakers. I am not plugged into the same outlet as their equipment. Could it be that I need to be? I get no hum from my own speakers. Only when I connect to their house a,b,c, box from my board.
Halon451
Halon451
Just kidding (previous post - not too many Bose fans around here just so you know :)), sounds like you simply have a ground loop issue. Try plugging everything into the same electrical circuit, if not the same outlet or power strip. ;)
Mitd
I've noticed that about Bose around this site. Thanks for the quick response, i'll try that.
bandphan
bandphan
Are you talking about a touchtunes system? Is the jukebox system the preamp? Does it hum when all electronics are off?
Midcow2
Midcow2
supernatural forces
"Poltergeist" tells the story of a suburban family living in a small town in California who's home is abruptly invaded by supernatural forces who are anything but friendly, and proceed to terrorize the entire clan. This is a movie that plays like a roller-coaster ride, and once it gets going it never stops.
The supernatural forces of ecltricity and electronics an Ht gods, hummed into a ground loop and fixed it with an APC power conditioner! http://www.nextag.com/APC-120-Volts-AV-517170039/prices-html
Mitd
No hum from the touchtunes. Only when I switch to my mixer through a,b,c switch which has no noise of it's own when connected to my speakers Bose stick L1 series 2 which has it's own amplifier built in to the base unit. The touchtunes system has it's own amplifier so all I am sending is a signal to the amp in the touchtunes.
Rickster71
Rickster71
Halon called it.
Sounds like a ground loop.
Get everything plugged into the same power source, even if you need an extension cord, and power strip.
