Connection Help HS51A RX-V2600 Bose AM16
jigar
Friends,
I am trying to setup my home theater with Sony HS51A,RX-V2600 and Bose AM16 speakers. I already hooked up speakers to Receiver but I am confuse with Projector setup.
1) Do I connect Projector Directly to DVD Player or Connect DVD to Receiver and then Receiver to Projector?
2) I have Dish DVR and also wanted to hook that up? How do I go about that?
Thanks
jigar said:
Friends,
Thanks
You have some nice gear, then you bought Bose. Have you listened to those speakers? Are you satisfied with them enough?
As to your question. It seems you have 2 video source you want to feed to the projector, sat and DVD.
You should wire both to the receiver, then one video cable to the projector.
This will depend on the highest resolution capability of each and hopefully the Yam can convert them both to send to the projector.
What is th ebest video out from the DVD player, HDMI, component video(3 color); same for your sat system, can it do component, HDMI, S-video?
How about that projector? Will it take HDMI or component video in?
jigar
Thanks mty. Yes I think I am satisfied with Bose.
Yes receiver has all HDMI,compo and s video. I connected everything and it seems works great now.
Thanks.
Thanks.
Great. Glad everything is working as it should. Enjoy. And don't worry about those Bose speakers:D
