connecting surrounds to subwoofer
skharrison211
I am embarking on a journey into 7.1 home theatre. This trek has taken me all over the internet and in some cases has created more questions than answers. Hence my arrival at Audioholics.
During one of my stopovers (i have no recollection of where i was) an enthusiast was heralding the merits of utilizing an additional subwoofer in conjunction with his surround speakers to extend the frequency lower (given that surrounds low frequency range often end in the 50hz range)thereby capturing more info and adding audibly to the surround effect.
(Finally) My question is... Has anyone attempted this feat and if so how was it accomplished?
(Additional info... I am contemplating the purchase of the Yamaha RXV-1800.
Thank you... thank you very much.
Davemcc
Davemcc
If you are set up correctly, surround information at a lower frequency than the crossover point will automatically be added to the LFE channel and come out the subwoofer. This is a non issue since low frequency bass is non-directional and doesn't need to originate from behind you.
However, there really is something to adding additional subwoofers to your system. Where the subs are physically placed in the room will be a function of the room itself, the listening environment. But the additional sub would be wasted if you were only going to feed it from the surround channel's frequencies. The surrounds simply don't have that much bass info to reproduce in normal circumstances and it is reproduced by the subwoofer anyway. If you wanted to fill in some surround bass, simply place the second subwoofer behind or beside you (integrated properly, of course) fed from the main LFE channel.
