Hi Markw,
Yes, you're right, I've tried using the Y-adaptor although I'm really hesitant doing it coz most cases I see was output split into two and not two combined into one, after trying I noticed a degration in the SQ, don't know what it is but my hearing tells me the sound quality degraded especially in the mains speakers (bookshelf type).
I called the store where I bought my amp and they suggested to used only one channel from the pre-out of the amp, will this be a problem? The sound quality is okay but I'm not sure if there will be impact in the long run...
It's true that my sub is a bit odd considering it has only one line level input but one factor also which made me choose this is the budget constraint at the moment,you know what I mean? by the way, my Sub is Audio Pro Sub Soniq model from Sweden, it has a decent specs, only that it has this only one line level input which is giving me this challenge...
Hey, thanks for taking time responding to my query...have a nice day man!
