Hi All,
I have samsung soundbar HW-T450 (pair with wireless subwoofer) that has only optical digital input. I want to upgrade my system into real 5.1 channel home theater using AV receiver, but I don't want wasted my existing soundbar & wireles subwoofer.
This is My Plan:
1. Using My soundbar as center channel speaker
2. Using Soundbar's subwoofer as 0.1 channel (Subwoofer is wireless and can only natively connected to soundbar)
3. Connect Center Channel & LFE(subwoofer) pre-out of my AV Receiver, to Analog To Digital (ADC) converter using stereo RCA cable as input and optical toslink as output, with following configuration:
a. Center Channel pre-out as L input in ADC
b. LFE Channel as R input in ADC
4. Connect optical toslink ADC output to Soundbars input.
My Questions is:
a. Does the soundbar can separate Center Channel & LFE signal, and deliver that signal into correct target?(Center channel signal to soundbar & LFE to subwoofer)
b. Does all speakers in soundbar received signal as "mono" or "stereo"? , I Prefer mono, because if stereo, according to input configuration, only L channel that containts Center Channel signal, meanwhile R channel will containts LFE channel signal)
Thank you in advance
Regards,
Hanya
