I'm setting up a new Denon AVR-2807 with a set of Polk speakers, and am having some issues with the subwoofer, model PSW303. I've read the documentation for both, and connected it as I think they are recommending. I used a audio cable from the 'sub out' on the receiver, to the top "Line In" (filtered) connector on the Polk. I've run the auto-setup on the Denon, and I do get test tones from the subwoofer, and it is set to 'yes' but I don't seem to be getting anything during playback of a DVD.
Some of my confusion:
- Is the sub out on the Denon AVR-2807 filtered or unfiltered, the docs do not specify.
- I guess related, shoudl the output from the sub out be connected to the "line in (filtered)" connector, or the "LFE (unfiltered) connector on the PSW303?
- The Denon instructions suggest setting the crossover frequency to it's maximum or the Low Pass filter off. The subwoofer has a dial marked "Low Pass" but it's not an on/off setting, it's a range from 60 to 160 Hz, so is this really the crossover frequency? Also, besides the normal power switch, which turns the power to the sub on/off, there is a switch marked POWER that has three positions, on/auto/off. This is not the Low Pass Filter setting is it?
I've apolgoize if this is a redundant post, or an ignorant question. I've searched this forum, Denon and Polk's web site, and have really hit a brick wall. Thanks for any pointers or suggestions.
David
