Hi, I bought a Denon AVR 2805 receiver (mainly for its audio capabilities) and would like to connect my TV to it. I think I would like to use the 2805 as the main node for all my audio and video streams.
The question is, How do I connect my TV to the 2805? Apparently, the 2805 can receive radio signals but not TV signals (which I find a bit surprising). I guess that means I will need to use my TV as the TV receiver. If that is correct, how do I get the TV signals into the 2805 (e.g., to forward them to a VCR or so)? Do I need to buy an extra TV receiver? If yes, which kind?
Note, my TV is a cheap Panasonic with a coax input (for the antenna or cable), and a front panel for AV input, plus a headphone connector. I currently use the TV as a 'monitor' for the video coming from the 2805, and that works fine, but how do I use it as a source?
Thank you for your help,
--Martin
