http://www.radioshack.com/product/index.jsp?productId=2062472
Why do you need an adapter when you can just buy rca terminals, splice the copper wire and attach it. :/ The adapter doesn't nothing more than exactly that. The rca terminals will cost you $5 and the adapter will cost you a lot more. It's a no brainer.
because it would be too much gain for the input that way,it needs to be stepped down to a usable less distorted level,and the voltage/current needs to be stepped down,
you just said it yourself !
because the high-level input on your amp has a circuitry built in to lower the input power through that signal.
that's why most amps have 2 types,speaker level input & rca pre amp input,
the input needs to be somewhat "matched" for the output to not be over driven and start clipping,
hi/lo adapters are a little more than just rca plugs stripped & connected to wires,
sure you could ghetto rig it that way to make sound your way,but it could damage the amp and it would sound really really crappy.
but then that's what a lot of people think is good bass in a car anyway !
"no brainer" ? LOL
and the following you said is untrue
I am not sure what the person above is getting at but there will be 0 compromise in sound quality going this route
there is a huge difference in sound quality in using speaker level input and true low level pre amp input(no matter how you connect the speaker level input)
