I'm awaiting the arrival of my Panny DMP BD80 player on Monday.
I'd like to get any necessary cables on order to hook it up to the net for updates and the on-line features. I downloaded a copy of the manual and it shows a LAN cable needs to be run when hooking up to a modem.
The book specifies a network capable of 6Mbps minimum.(no problem there)
But I want to make sure I get a cable that will not restrict any speed. All the cable listings are rated as "mhz" with 500 mhz being the fastest listed, will that be enough? I don't know anything about this part of connecting.
What effect does distance have if any? (I'm looking at a 50 foot plus run from the family room to my modem in the den)
Last question...The unit has a USB port, can I use that with a Wi-fi dongle instead of running the LAN cable?
The manual does not cover anything about Wi-fi.
Thanks
E.
