I want to add an
NHT CS 10 subwoofer. Is it possible to connect it to this linn majik I amp?
You can because your sub has right and left inputs. You need to use both and keep them discrete, as preouts are not buffered, and so if you join them you will have mono right across your system. For this reason many subs like yours have buffered inputs. So the channels are commoned after the buffer amps of the right and left inputs.
