Connecting a PC to the JVC hd56fn97
skilz853
I just bought the JVC hd56fn97 and had visions of hooking up my computer to it and with wireless keyboard, sit back in recliner and surf the web. When ever I connected the PC, it first showed a splash screen saying windows 2000 is starting up. Then it'd go no farther and "invalid signal" flashes on the screen. The only way I could get it to work was by stating windows in vga mode, which is only 16 colors and is totally useless. Please tell me there's a solution. Thanks Skilz
The Chukker
The Chukker
What is the native resolution of the tv? Are you sure that your control panel settings match? If you are using an HDTV as a monitor then I highly doubt that your color settings are the culprit; HDTV's are quite capable in that regard.
