<font color='#000000'>Hi Audioman,
Thanks for your advice. Unfortunately someone deleted over half my original post. As you can see by my above post, I had much more data for you to work with.. I would never post such a question while giving only so little data!
I do have a splitter, its got the ends reversed on it for some reason.
If i do that daisy chain thing, will one sub be louder, or quieter or sound better than the other?
In other words, is there a down side to doing this?
Thanks,
Rob</font>
