CONNECTING 2 DIFFERENT MADE SUBWOOFERS
Y
Yiannis
Dear friends,
I'm new here and I would like your opinion. I have the reciever DENON 7.2 model 3313 with (5) speakers B&W (VM1) and (1) subwoofer 10 inches B&W (ASW600). Can I connect another brand subwoofer with the same diameter 10 inches?
Thanks
WaynePflughaupt
WaynePflughaupt
Yes you can, not a problem at all.
Regards,
Wayne A. Pflughaupt
Might be easier to integrate two identical subs (and that is not just based on the diameter of the driver, but rather make and model), but no reason not to give it a try. I'd set them at equal distances from your seat since the avr doesn't have the ability to make level/delay adjustments for two different sub locations.
