connect wireless microphones to denon AVR
G
goose99
I have a denon AVR 1295w that connects to a epson projector and 5 polk audio speakers. I am able to play music through my phone that comes through the speakers without issue. I purchased a two wireless microphone system that I purchased today. The microphone receiver has a power cable and 1 large jack cable to connect to what I assume is a speaker. The denon does not have a port for the microphone receiver. How can I connect the microphones to the denon so I can hear the sound through the speakers?
This is the microphone that I have --
NASUM UHF Dual Channel Professional Handheld Wireless Microphone System with Dual Wireless Dynamic Microphones,LCD Display Professional Home KTV Set for Party,Meeting,Karaoke,Youtube,Classroom black
thanks for the help!
WaynePflughaupt
WaynePflughaupt
You can use any input on the Denon, except a Phono input. You’ll need cables with 1/4"connectors on one end and RCA’s on the other.
P.S. don’t drop the mic while it’s on – it’ll probably blow your speakers.
Regards,
Wayne A. Pflughaupt
L
Leemix
You probably need a microphone/headphone(unsure about size on your wireless box, might be 6.5mm) jack to RCA left and right adapter cable.
BMXTRIX
BMXTRIX
You need this:
https://www.amazon.com/Audio2000s-Acc3122-Dual-Jacks-Adapter/dp/B006ZCXBN0/ref=sr_1_1_sspa?keywords=rca+mono+to+stereo&qid=1560363153&s=musical-instruments&sr=1-1-spons&psc=1
Then just use a standard red/white RCA connector cable to connect the microphone to the A/V receiver.
This is not a 'mixed' solution. You will hear the microphone or you will hear the music, but you won't hear both at once.
If you want to hear both the music and the microphone, you will need a audio mixer to do so. Some cheap karaoke systems have a built in mixer, but cheap mixers are all over the place as well.
ie: https://www.amazon.com/Behringer-502-Premium-5-Input-British/dp/B000J5UEGQ/ref=sr_1_5?keywords=audio+mixer&qid=1560363381&s=musical-instruments&sr=1-5
WaynePflughaupt
WaynePflughaupt
The Behringer can connect to any AVR. In order to do Karaoke, you must connect both your music source and the mic receiver to the Behringer. Otherwise there is no way to mix the levels of the two.
Regards,
Wayne A. Pflughaupt
Missta
Missta
Regards,
Wayne A. Pflughaupt
If I understand this correctly, I need to connect the smart TV audio to the behringer and then output both microphone and audio from the Behringer to the denon reciever? What about the HDMI that's connecting the Smart TV to the Denon and surround sound speakers?
WaynePflughaupt
WaynePflughaupt
The Behringer requires analog inputs. You will not be able to view the TV and use the Behringer mixer at the same time.
Regards,
Wayne A. Pflughaupt
