connect Pioneer A-20 amp to Denon AVR-X5200w HOW?
N
NewbieAVMike
I have the Denon AVR-X5200w and purchased the Pioneer A-20 2ch for the Front Ceiling speakers(not the rear as stated in the manual). I would like to do the Atmos 7.1.4 configuration. Just confused on where to plug in the TFR, TFL to the Pioneer A-20. Any detail info would be much appreciated. Newbie AV guy. Thanks in advance.
You should be able to connect the pre-outs on the Denon to any of the line inputs (except the Phono input) on the A20. Why did you get an integrated amp instead of a power amp, tho?
N
NewbieAVMike
a friend had one but should I get just a power amp instead? thanks for the reply
Depends on the price and power you need but much of the feature set of the integrated amp won't be used when just used as a power amp....it should work fine once you find a good setting for the volume control on the A20.
