jason76
I need help understanding how to hook up my new toys. What I have to work with is a mitsubishi 73"hdtv model#wd73734(has 3 hdmi's), Harmon Kardon receiver model AVR247 with 2 hdmi inpts, 1 hdmi output, panasonic blu ray dvd player model#dmp-bd30 +toshiba hd dvd model# hd-a30(both have hdmi) and last a direct tv hd reciever w hdmi. Im really confused on the proper way to connect them but I would like to do it w/hmdi cords only if possible so I get the best quality picture from everything
Adam
Adam
Jason,
Welcome to the forum!
So, here's what I get from your post. You have 3 HDMI video sources, but your receiver only has 2 HMDI inputs. You can hook all three into your TV directly, but let's look at some options to take advantage of your receiver. After all, your receiver will process the audio coming over HDMI, so it would be great to connect through it. Some options that come to mind:
1. Connect two of the source components (e.g. HD-DVD and Blu-ray player) to the receiver using HDMI. Connect the other source component (e.g. DirecTV) to the TV using HDMI and to the receiver using a digital audio connection (either Toslink optical or digital coax, whichever is available). Lastly, connect the receiver to the TV using an HDMI cable. That way, you'd get audio from all three sources to play through your receiver; you'd get video to the TV using HDMI from all three sources; but you'd need to switch video inputs on the TV when you wanted to watch the third source (in this example, the DirecTV box). The reason that I suggest plugging the two disc players into the receiver using HDMI is because they can pass higher quality audio over HDMI than over Toslink or digital coax. However, I doubt that the DirecTV box can (at least this generation of DirecTV boxes).
2. Buy an external HMDI switch box that would allow you to effectively plug all three HMDI sources into your receiver. Others here have more experience with those.
Adam
Seth=L
Seth=L
I would assume your TV has more than one HDMI input, if not, you can use component video connections for your DirectTV box. If you do have more than one HDMI connection on the TV then you can directly connect HDMI from the DirectTV box to the TV with the others connected to the Harman Kardon (to utilize the HD audio processing available on the Blu-ray and HD DVD players. Be sure to set the HD DVD and Blu-ray players to LPCM output over HDMI to get the best SQ.
