Hello, I'm trying to maximize space in my theater room so would like to put the screen against the far wall (180" screen). However I'm also committed to optimizing the layout for the very best sound quality, so want the speakers about 4 feet from the back wall.
The center speaker needs to track closely to the screen for off-axis viewers, so seems the center speaker needs to be against the wall with the screen. Are center speakers made to not need the same distance from back walls -- I ask because I so often see them mounted on back walls.
If the center speaker and screen are against the screen wall, is it a problem to then pull the left and right front speakers out 4 feet from the wall, or does that create problematic inconsistencies in blending with the center speaker that is four feet behind it in this scenario?
Using Martin Logan Theater i center and SL-3 speakers for left and right fronts. The room is fairly large 20' wide and about 40 ft long (screen as along the 20 foot wall). Screen is 180" and the SL-3 left/right speakers are on the sides of the screen, the center is underneath the screen (the screen is not audio transparent).
Thank you!
