Conditioner/Surge Protector on Dedicated Circuit?
E
Electone
I am running 2 dedicated 15 amp circuits for my HT system. I would tend to believe that this is the cleanest way to get power to your equipment. Do I need power conditioners and/or surge protectors?
Tempest
Tempest
Good start
Unless your electricity is 'dirty', you probably don't need a conditioner, but I would highly recommend good quality surge protection! I live in Florida and have seen a lot of nice stuff get toasted.
JohnA
JohnA
The two dedicated circuits are a great start, however, all power coming off the pole will fluctuate (by how much is anyone's guess). The farther out you are the more likely you will have greater fluctuations in voltage. I have not used a voltage regulator/line conditioner (if I had the cash I would) without any problems. A quality surge suppression is needed for any system, I would suggest either Furman or Tripp Lite, Furman just released an affordable line of power centers for home theater use. If you are worried about voltage drops and spikes then buy a regulator...It is a small amount of $$$ when the entire system is at risk. You can buy or borrow a clamp on AC/DC DMM and you will be able to tell the voltage changes on the lines.
Mort Corey
If you're going to go to all the trouble of running dedicated lines to your panel, it would be a great time to incorporate a whole house surge surpressor at the box. It's a good first line of defense.
Mort
Tempest
Tempest
Yes!
Mort
An excellent idea!! :cool:
