Thanks for all of your replys - you give a guy a lot to think about but net, net I think I need to look for a new amp. I have too much invested in the speakers to swap them out, good or bad. I just wish I had looked harder at them to find that they were 4ohm not 12.
Yeah, the ol' DENON was warmin' up a bit. Although I've had no problems the heat did bother me and the volume just never "filled" me up. I kept thinking something had to be wrong and that's when I discovered the speakers were 4ohms. (yeah, I know kindda stupid on my part. I just assumed they were 12ohms. Why would they make them 4 ohms?. Answer that mr Polk rep.)
We have a room that is 15' x 27', not huge but it still takes some volume to fill. I probably went overboard by buying the 15's after already having th 25's but I got a deal that I just couldn't turn down.
So, now I have to figure how to start over. the DENON is not an option for a pre-amp config. It only has HDMI 1.1. Seems like I ought to start from scratch but how much is scratch gonna cost? Time to start shopping.
Again, thanks to all that have replied. I'm a bit confused still but I think I have the jest of it.
Regards,
Kent
