<font color='#008080'>If you're hooking it up using the options presented, you'll want to run an S-Video cable to get the best picture quality. The yellow connectors are most likely the outputs from the computer (red should be the inputs, which you aren't using)
You'll also need to run audio from your audio output to your TV/receiver in order to hear anything.
Ideally, you would have a sound card with an optical digital output, then run that to your receiver with optical digital inputs. However, analogue will suffice if you do not have the capability to do this.</font>
