composite cable (2 RJ45, 2 RG6QS) ?
rma123
Not sure if this is the right place. I am looking for 200ft of this cable. It consists of 4 cables: 2 RJ45, 1 for cable and 1 for satellite. I found some places which sell them and are pretty expensive. Does anyone out there have any recommendations?
Thanks
Ray
CraigA
We sell something we like to use for structred wire locations in the house. It consists of 4 cables, (2) CAT5 and (2) COAX. It works very well with the Elan SWPDC. The (2) CAT5s are used for phone and data while the (2) COAX are used for either cable or satellite.
I dont know what your application is, but if you can fill me in then I might be able to help.
rma123
Hi: thatz what I need the cable for. I am finishing up my basement and installing some outlets for my TV and computer. Could you please let know approx how much do you sell it for (per feet)
Thanks
Ray
We sell something we like to use for structred wire locations in the house. It consists of 4 cables, (2) CAT5 and (2) COAX. I works very well with the Elan SWPDC. The (2) CAT5s are used for phone and data while the (2) COAX are used for either cable or satellite.
JonBaker99
It will probably be easier and cheaper to go to home depot and buy 500 ft of RG6 and Cat5E and make your own.
Haoleb
Haoleb
Yeah, For such a small job theres no reason why you should need the bundled cable. We also use this cable where I work but if we dont have any on hand we just run regular cat5 and coax. The only read advantage of this type of cable is that it may or may not have a seperate foil sheild. But I wouldnt track down the stuff halfway across the world for any reason.
