Last year I built my home and planned for a Plasma TV above the fireplace. At that time, I was more of a novice than I am now and regretfully installed a single one inch conduit between the AV cabinet and a spot above my fireplace. I wish I would have installed two 2" conduits, but I can't change that now. The conduit run is roughly 25 feet. I purchased SonicWave's 25 foot component video interconnect from Impact Acoustics. Upon arrival I noticed the three individual cables making up the interconnect should fit inside a 1" conduit, but the thick plastic piece at either end stopping the three individual cables from splitting apart is wider than 1". I have two questions for the forum:
1. Can I remove the plastic piece from each end or does this serve another function other than to hold the three cables together and stop further splitting?
2. Does anyone have a suggestion for a quality component interconnect that will fit inside a 1" conduit?
Ideally I would like to fit 1 component interconnect and 1 HDMI interconnect in the same 1 inch pipe. I may be asking for too much, but if anyone can give insight I would appreciate it.
Here is the system I am installing in case you have other ideas:
Monitor: Panasonic TH-50PHD8UK
A/V Receiver: Yamaha RX-V800 (will be upgraded to an HDMI compatible receiver sometime in the future)
DVD: Denon 2910
HD Cable: Motorola Mark IV
DVR: TiVo R2400A
Front: Boston Acoustics VRB
Center: Boston Acoustics VRC
Surround: Boston Acoustics VRX
Sub: Definitive Technology SuperCube II
