Component Video Cables for Audio
photoeye
So do component video cables make for a better audio cable?
other than the 75ohm impedance with the c.v., it should
work just as well as the 50ohm standard audio interconnect?
reason I ask is I'm sure we all have quite a few of these cables
lying around since HDMI came out. maybe good way to recyle as audio
interconnects.
markw
You'll be fine using video cables for audio. They have a wider bandwidth and aren't as fussy abut impedance as video/digital cables.
And, as an added bonus, most modern audio cables are 75 ohms anyway.
photoeye
good to know. thanks. :D
I'll use them between my AVR and external amp,etc...
L
ldgibson76
interconnects.
Hello photoeye.
I use component video cables for multi-channel audio on my Denon DVD2910 and it works fine. I was told by a technician at a high-end audio/video store that it would work perfectly. He was right.
Regards.
