Component Video - 120ft
marklarry28
Hi folks,
What is the good cable to run 120ft of component video?
Can I use any standard cable? (I mean any good cable for Component Video)
marklarry28 said:
Hi folks,
Someone asked this before, maybe you?
That is a very long way to send signals from such components. Maybe if you called Blue Jeans cables, them may help with that distance?
Cobalt Cable
marklarry28 said:
Hi folks,
When you start talking about long runs, shielding, and conductor size play a major role(find specs on the cable before you buy so you know what you're getting). In general, analog cables can pull off much longer runs than their digital counterparts. The best advice I could give is just compare specs of each product you're considering and go from there. Some manufacturers tell you some don't. Good luck!
Feel free to PM me if you have further questions, be happy to help.
