nuance
nuance
on a scale of 1-10 how much of an improvement do component cables make over the single RCA video input? I'm getting a 52" HDTV upgrading my 27" Tube TV and am wondering if it is worth the little extra money?
jaxvon
jaxvon
An insane amount. There is NO comparison. Even upgrading to S-Video is a substantial difference, with Component being far better.
Where were you planning on shopping for component video cables?
nuance
nuance
dunno......the source (Radioshack) something like that....... any suggestions on a "middle of the road" quality and price?
t3031999
A single composite RCA cable would look really bad compared to component on your new TV.
I am a huge fan of the SONICWAVE cables from Impact Acoustics
I'm sure their velocity cables would also do a very good job for about half the price of the SONICWAVEs.
I don't have any experience with them, but a lot of people on this forum seem to like Blue Jeans Cables
Sheep
Sheep
One word: Rona.
I just picked up 250feet of 12ga. speaker wire for 100bucks there. They sell good video cables and are not monster expensive.
SheepStar
nuance
nuance
Sheep said:
One word: Rona.
SheepStar
I never thought of them.... I remeber seeing some stuff there but it one of those places that you don't think to look. Thanks
N
Nick250
The other suggestions are fine and Radio Shack will have perfectly fine component cable at competetive price as well.
5
5.1 DTS guy
I upgraded to component video cables for my 27 inch crt tv, and I hardly notice a difference. If you have a digital tv component cables are a must to watch movies in progressive scan and get the best picture quality. Do you guys think Avia will help my component video look better?
BassHead
I have tried several cables and hardly see any difference in video quality,I run the best cable from audioquest for component and see no change,Also tried AR,blue jeans,monster and others with no change,I normally ran a single video to my sony 43" from my monitor out on receiver and video quality is just as good,So really you blow your money when you could spend it on some thing else.
As 5.1 DTS Guy mentioned, to get progressive scan with a capable player you MUST use component or DVI/HDMI.
When switching between various component cables, you have to recalibrate for each one, otherwise you WON'T see any difference with the same settings on your display. I've tried a number of component cables too, and Blue Jeans are my favorite so far.
Check out this video cable comparison:D
http://www.provide.net/~djcarlst/abx_vid.htm
Note what that 40+ meter cable was. a 16ga 120V extension cord:D
SCOTTI0223
i just installed component cables for by digital cable and everything is coming up grey and purple....whats the deal with that
thanks scott
thanks scott
I presume you are talking digital cable TV box? Maybe it is not sending component video out? Have you called the cable company?
Or, are you sure you connected the right colors at each end?
L
Leprkon
go down to Wally World...
very good component cable set ($10): http://www.walmart.com/catalog/product.do?product_id=1717306&cat=4537&type=19&dept=3944&path=0:3944:133276:133270:4537
slightly better construction ($23):
http://www.walmart.com/catalog/product.do?product_id=2625044&cat=4537&type=19&dept=3944&path=0:3944:133276:133270:4537
and yes, they are what I run on my system (Phillips on main system, RCA on bedroom HT, more because they only had one of each in stock when I was there than actual preference)
SCOTTI0223
i guess my next step is to call the cable company. yes it is digital cable box. last night i switched the cables around to see if for some reason the cale were bad or hooked up wrong and everything is right but the pic. thanks
Stoner51
I had this problem with a DVD player the component cable hookup wasn't active from the factory you had to set it to be active. My picture was similar, the color was off but you could see the picture. Just a thought.
