I'm trying build a HT in the basement with superior isolation. My plans include double wall construction (i.e., two seperate stud walls) between the HT and the adjacent living space. The stud walls will be connected to the ceiling joists with DC-04 isolation clips. In order to maximize the STC I'm loking at installing two seperate doors in the entry. This should be significantly less expenses then purchasing a soundproof door for $2500. Each door will be an exterior grade metal door with a full seal around the door ($250 each). Each door will swing open in an opposite direction. My question is how to install the two door jams. Since there will be a 1" gap between the two walls, I assume I will have something a little less than an inch gap between the two door jams. I don't think I want a ridge connection between the two, since this defeats the whole purpose on installing a double wall. One thought is to use some MLV behind the door jam which will span the gap. Another idea is to use some backer rod and chalk the gap with Green Glue. Does anyone have any ideas?
