does any one know what equipment commercial movie theater use for sound amps ? subs ?
R rcpilot_971 Audioholic Dec 27, 2008 #1 does any one know what equipment commercial movie theater use for sound amps ? subs ?
bandphan Banned Dec 28, 2008 #2 http://forums.audioholics.com/forums/showthread.php?t=49678 http://forums.audioholics.com/forums/showthread.php?t=49948 the two brands discussed in the above threads would quailify for the subs and speakers as for power......high power pro gear yamaha, hafler, ect ect
skizzerflake Audioholic Field Marshall Dec 28, 2008 #3 Try web sites by JBL or Pro Acoustics. Both have info about commercial sound systems.
Phil Taylor Senior Audioholic Dec 28, 2008 #4 Back in the day some used Altec Lansing "Voice of the Theater" cabs... that's been awhile ago though...
Halon451 Audioholic Samurai Dec 29, 2008 #5 I do belive these are used quite a bit, depending on the theater chain... http://www.jblpro.com/products/cinema/index.html Not quite sure what they typically use to power them though...
DD66000 Senior Audioholic Dec 29, 2008 #6 All the theaters I've been in the last few decades have used JBL Pro speakers. So I would assume the gear was JBL also.
