rcpilot_971
coaxial digital or optical cable for sound or does it matter much
Thanks Tim
Thanks Tim
When I first got into higher end audio a salesman told me that optical was inferior to coax. Yes, in sound. My DAC has coax and AES/EBU inputs and I think I'm going to try the balanced input and see how much of a difference it makes. How much do you think this will make??Yep, Coaxial has higher bandwidth cabability as well, but it is never utilized. There is no audible difference.
Nada, zero, zilch, nothin.When I first got into higher end audio a salesman told me that optical was inferior to coax. Yes, in sound. My DAC has coax and AES/EBU inputs and I think I'm going to try the balanced input and see how much of a difference it makes. How much do you think this will make??
Fiber optics can have more bandwidth than copper, yes, but Toslink has very limited bandwidth. As mentioned before, the bandwidth is more than enough to get the job done using either medium.I will be first to admit I have very little experience between the two, but in theory I would have guessed optical would be superior in bandwidth (capacity), signal quality and immunity from interference. Plus being a smaller cable it would be easier to work with.
In my experience with fiber optic interfaces in the computer industry, fiber optic is generally regarded as having higher bandwidth over copper, and is preferred for most interfaces to high-speed devices. But maybe this concept doesn't necessarily apply to music as it does in computer channels.
Actually, toslink is more difficult to work with in tight spots since it can be broken if bent too sharply. It is only glass or plastic.The only thing with toslink is that it might be a little more easy work with smaller/flexible in tight places when you have tons of other wires and such in cramped spots.
