Does what matter- the amount of information given before asking the question? Yes, it matters, if you want an accurate response. Also, yes, it matters if you have the receiver between the source and the TV. If the distance to the TV is very long, using the receiver as your switching device is a good thing because a lot of receivers act as a repeater for the digital signal, which corrects errors and restores the signal level. This shouldn't be confused with an amplifier, though. Digital signal is on/off, not high and low amplitude.
Also, I would still like to know what kind of set top box you're using. I haven't seen one with Cat5e video input/output and it seems odd that they might install the needed circuitry if most people won't use it. I asked if you're using U-verse and I still haven't seen an answer. They're the only ones (or some other FIOS provider) I know of that use Cat5e for anything other than just network connections.
