Coax connector issue Denon S-101 tuner
marcl2007
Hello, any suggestions?
After attempting to connect 3 good coaxial cable sources from my home, from any of the existing sources that works perfectly well when the TV's are connected to it...I can no longer pick up ANY channels from the tuner on the Denon S-101.
I currently suspect that the connector from the Denon has just gone faulty as interesting enough if you insert the coaxial cable just very slightly in I do pick up a signal but as soon as i insert further in and turn the screw the signal dissappears...???
I just have a hard time beleiving that this connector is broken?...now unless there is a special setting from a Denon on-screen menu point of view that I need to change?...
thanks Marc.
thanks Marc.
Me too.
Are you connecting a cable TV cable that has FM on it, or a coax from an FM antenna? If the former, that would be your issue, I bet, unless it is so designed to accept cable TV FM.
