What is the best way to use Quad Shielded Coax for RGB Component Cable? Do you Splice F connectors to the ends and then screw a F to RCA adapter onto the end. Then plug that into an RCA to RCA Wall plate? Or do you try to solder(which I haven't done since science projects in 6th grade) RCA jacks onto the coax ends and then plug that into the RCA to RCA wall plate? Thanks for the help. Paul
