Coax and Power Strip?
E
ebeach
The company i work for is setting up a TV wall like you see at Best Buy and such. I have found at a store a surge strip and with every power outlet there is a coax port. Has anyone ever seen this? Where can I get one? The maker I noticed was TvTrac.
lsiberian
lsiberian
APC has a lot of very good power strips. I suggest you contact them and they may be able to suggest the appropriate solution.
E
ebeach
Ya that is what i had hoped but seems this is going to be difficult to find. I talked with my cable provider and they can't find it either. Stumper.:confused:
