The solution I posted under my original problem statement titled
"Need help with my LG LCD Model #42LB5D"
is as follows:
Well I stumbled onto the solution to my problem of not being able to get closed caption reception.
My HD Cable service provider is Charter.
My TV is a LG LCT 42" (Model # 42LB5D).
My cable box is a Motorola DCH 6416.
Solution to getting to the closed caption option is to turn the tv on, and the cable box off (it must be off inorder to bring up the "user setting menu"). Then on the front of the cable box press the menu button (again box must be off!), and this will bring up the "user setting" options and among many options is the closed caption option. My CC was set to off. I turned it on and now all is well. Also, there are other option available listed there to help you fine tune the HD reception.
I hope this is clear and of help to someone out there. It breaks my heart to read on Google all of the problems the hearing impared are having with this issue. The solution is simple once you find it . . . Isn't that the way it always is?
It is just too bad that when you go to the tech support who should be on top to this stuff they don't have a clue.
