Close out specials -
Three way
<font color='#000000'>I can buy a H/K AVR 7200 for $788 or a Denon 3803 for $849. &nbsp;Both have become victims of technology and since newer models are out on the market these two great receivers are clearance closeout specials.
They will be driving Cambridgw Soundworks MC300's, a CS 12&quot; subwoofer, CS Centerstage center channel speaker, (4) S300 Surround speakers and using the multizone feature I will be also be driving (2) Klipsch Forte speakers.
Which receiver should I get?</font>
Z
zumbo
<font color='#000000'>Flip a coin.
I would give the nod to the H/K.
Some will say Denon.
You can't go wrong with either!
</font>
N
nm2285
<font color='#000000'>The best advice anyone on here can give is to listen to them both on your system (or at least on the same system). &nbsp;They will have different sound characteristics (although I won't tell you what to expect so I don't color your opinion) and one may be a much better match for your speakers than the other.
good luck choosing</font>
