Hi everyone. I’ve been away for a while but have a question.
I’m running a Denon AVR2308CI for my home theater. The receiver It is about 15 years old but still in mint shape. It has HDMI in and outputs.
The subwoofer out jack is connected to a Yamaha PX3 power amp, which is connected to my home made Eminence Lab 12 sub. The sub has no crossover but the high and low pass settings and parametric EQ etc... are all available in the PX3. The PX3 is in summed mode and puts out 600 watts RMS. It has Protection and Clip lights on the front. On the Subwoofer setup page in the Denon, I must set the signal sent to the Yamaha to +15 dB. I know that sounds like a ton of boost but without that, I need to bump the Yamaha up nearly full to drive the Lab12. It has worked perfectly for the past 8 months. All of sudden, I’m seeing either the Clip or Protection light flashing on rare occasions. I can’t see which light it is because I sit back 14 feet from the TV. The amp is right beside it.
Assuming all cabling is fine, what do you think is causing this? Many thanks.
