Johnd said:
A properly installed dedicated circuit with a dedicated ground, as was recommended, will give you the cleanest power available, short of a re-generator. Period. You failed to respond to this advice...I think that's all that was meant (certainly by me). Post your review on the Fuhrman after the test drive...I'll read it. Cheers.
Sorry, I was unclear. I had investigated the costs involved in getting me a dedicated circuit which I agree would be the best. Because of some issues in my house it would be very expensive, in the thousands of bucks. I would have to run a new service from the transformer to the house
Hence looking for a lower cost alternative that would help. I did detail all the reasons above why I think I'd like something between my fairly expensive equipment and the wall plug. IMHO the situation with that issue is even worse and more confusing than that with cables!!!!
There are a number of different potential solutions with the usual confusion and hype which is very difficult to navigate through.
The Furman arrived. Very solid, quality unit. Looking at the specs, it seems to offer pretty much everything that the far more expensive units do. I plugged it in, and it works, my system still works. Now when I made a claim of hearing a difference as my Behringer amp.... er.... got more hours on it, my throat got jumped down and the thread got hijacked into a discussion about the nature of science.
So.... I make no claim, but I am fairly familiar with live Taiko drums and have attended many live performances. Taiko (those huge Japanese drums) recording put a big demand on amplifiers as there is a big very deep bass spike (some of those drums are over 7' in diameter), with a bunch of higher frequencies riding along with gives each drum its unique sound.
Now, with my system, my Taiko CD sounded good, but not quite live. It
seems to me that with the Furman in the loop, it sounds more like a live performance and it seems that I can hear more of the unique characteristics of each drum on CD's that I was very familiar with. Of course, I could be deluded about this.
Never the less, if someone is looking for some sort of power conditioning, for whatever the reason, this unit is well worth considering over the far more expensive 'audiophile' ones. It looks to do pretty much everything you might wish to be done to your incoming power (surge suppression, filtering, and such), and I will state for the record that, at the very worst, it does no harm.
