Chroma Delay Denon DVD 3910 (Aust)
Moli
My 3910 in pal has a chroma delay problem. Bought it back to the store and checked out another.. same problem, tried a 2910 and yes same problem. (same board)
Denon Australia are aware of this problem that the DVD 3190 has this issue with Pal Zone 4 (after the owner rang Denon) and YES and firmwire upgrade to solve this prob is about 2- weeks away.
Check with a colour dvd or THX optimizer and the problem is with green and magenta you will notice a bleeding
No issues at all with NTSC.
Moli
Mr.T
Moli, thank you for the info.
So, anyone who had bought this unit in the USA doen't have to worry about chroma delay, correct?
Our beautiful planets, appreciate them.
________________________________________________________________
Moli
Thank should be correct unless they watch a Zone 4 or PAL movie
Jason Coleman
Denon's latest firmware-fix disc addresses the following known problems on the following serial #'s:
From AVSForum's "3910 Owner's Thread":
Chroma spread
black xxxxx3499 or lower
silver xxxxx0599 or lower
Picture disappears
black xxxxx2099 or lower
silver xxxxx0399 or lower
White belt
silver none
Jason
superman180
superman180
Maybe this has been answered somewhere else and if so please direct me to it. What is chroma delay, I here a lot about this.
Mr.T
Chroma delay, is self explainatory- Color has a delay in coming on, you get a black and white picture first then the color pops on.
Superman, I am not totally familiar with this feature but, it looks like that adjustable chroma delay is a feature on the Denon DVD-3910 Canadian model that allows you to adjust chroma delays thru the menu or a potenziometer (open for comments on this), look at the specs:
http://www.denon.ca/html/product_display.asp?id=213
Moli
An Australian firmwire upgrade to rectify the problem has been issued. I took my 3910 to Denon's recommended repairer and within a few hours picked it up.
No more chroma delay. The picture is awesome as it should be.
Moli
