Choosing between Marantz 8015 and 8012.......
audioboy9317
8015 is selling at $3,799. I found a new 8012 for $2,499. For general home theater use, would the 8012 be just as good?
Also..........how can you tell if a receiver has HDMI 2.1?
The 8015 has HDMI 2.1, the 8012 has 2.0. It says so in the specs sections.
They will sound equally good.
Probably, just depends what feature set fits your needs better. Do you really need HDMI 2.1? Personally I wouldn't need it.
Trebdp83
There are a few feature differences to consider between them. Some may want those features while others have no use for them.
