I'm in the final stages of planning my next, and frankly possibly my last, mains speakers. (I thought that once before, when I had Nathan build me low-diffraction cabinets for the Tannoy System 12 DMT II Dual Concentrics, but those speakers are simply too wide to fit here.)
The basic idea is three fairly narrow closed box woofer-concentric-woofer mains, with the left and right speakers resting on "flanking subs" so the space under them is not wasted. The left and right cabinets, depending on cost to get done, may have angled front baffles like the old NHT speakers. Aesthetics will closely follow my BDI Cirrus media cabinet's, with espresso oak veneer finish.
Concentric will have a passive crossover. Woofers will start active (miniDSP 8x8), but I may go passive later. Flanking subs will definitely be active, with the AVR providing crossover. Crossover starting points will be 2.5kHz, 500Hz, and 150Hz.
Here's what I'm thinking, parts-wise.
Concentric driver.
Two potential options on hand.
(1) KEF Q100 driver. Cheap, damn good,
and easy to work with.
(2) Pioneer Elite S-3EX driver. This driver is technically their third-tier concentric, with the beryllium cone/beryllium dome TAD driver being on top, the Elite EX magnesium cone/beryllium dome driver being #2, and this magnesium cone/ceramic-graphite dome being #3. But that strikes me a bit like ranking RG3, Aaron Rodgers, and Matt Ryan. Who wouldn't be happy with any of the three? But, it's a lot more difficult to work with than the KEF driver, and if a botch something the KEF driver costs ~$150 to replace but the Pioneer driver costs like $500...
(2) Mains woofers.
My first choice is actually a "car-fi" driver, the JBL C660GTi's piece. Huge throw, killer motor, and small flange. Problem is, I bought two rather than six, and now they're out.
Other options are the Aura NS6, and a Pioneer Elite EX 7" sandwich-cone driver. The Pio woofer has a fairly small motor (35mm vc), but it does have very normalized inductance (almost in Aurasound territory at ~0.15mH/Ω). a pro-style multiroll surround, and does definitely look like an expensive driver. But the 7" flange will make for wider-than-ideal speakers.
Flanking subs
Three choices here. The most likely option is that I'll use my Aurasound NS12-794-4A's. They can play higher than any other good sub, and I just generally love the Aurasound drivers. All of my other subs in current use have Aurasound drivers.
The other main option I'm considering are the JBL SUB1500's that have been sitting idle for too long. These were the woofers used in the Revel Ultima Sub. They have more volume displacement.
As a dark horse, I could also do dual-opposed Peerless 830500 XLS12's without buying a thing...
I may also do two completely distinct variants, a "budget" one with the Q100 driver and NS6's in the PE 1 cube MTM cab, and a "high end" one with all Pio drivers in a bespoke cab. The ones I prefer will be mains; the ones I don't can be side surrounds.
