trw005
Under $450 pr. Showdown
Ty for ur posts all. Did my research and i ask for your opinions now. I have my selection parred down to this in order of favorites:
Axiom M3ti, Ascend CBM-170, PSB B25, Paradigm Monitor 3 or mini
I will use them as fronts for HT system in small room 12 x 12.
Have new Onkyo TX-SR503 75 w/ch 7.1 I'm not looking to be told which is best, just opinions of owners of these or peeps who have heard them and
what they thought of them vs. each other or vs. others not mentioned. :)
Shinerman
Shinerman
Iwill use them as fronts for starter HT system in small room 12 x 12.
Have new Onkyo TX-SR503 75 w/ch 7.1 Ok ....analyze. :)
Have you listened to any of these speakers? If not, that would be the first thing to do. We can't tell you which speaker is better. That's for you to decide. All the speakers you mentioned are "good" speakers. Just go with the ones you like the best.
Shinerman
silversurfer
now that you have narrowed the list, you really should try and get a listen to all of them, and preferably in the same environment.
Tex-amp
What is your center channel? You should really being timbre matching your center.
