Checking Biamping of 3805
Jack
Guest
If I have biamped my front speakers correctly using the method described on this site:
Is it then correct that when I run the auto set up function of the 3805 a test sound should come out of the bass portion of my front speakers when the 3805 sends out the pink noise to the surround L/R set B?
When I do this I do not hear anything for the surround b's. Maybe I've done something stupid!
Thanks.
tsteves
No, I don't remember it that way. Sound should only come out with the A front LR's.
Not in the mood to redo mine at the moment.
Make sure to use an input you may not accidently hit. Not good. feedback.
This setup has done wonders for my maggies, definately worth it if you have inneficient speakers.
Jason Coleman
Jack-
I'd also suggest double-checking your connections and Zone 2 input setting in the Sys Setup menus. I hope you can figure it out...it's definitely a nice bonus feature of the 3805.
Jason
