Ever wonder how fast your jalopy of a computer runs
 (or have not checked in a while, like me..
Or what all the running processes in the background are?
Or check how well your security is?
Just want a quick glance at your system performance?
Well, this is one of the quickest & easiest tests to run (other than downloading a full benchmark suite)
There is no downloading needed (other than allowing a harmless acticeX control), the test is fairly accurate, and shows how you rank to compared systems.
You DO NOT have to sign up for anything, you DO NOT have to give any info.
Just go to the link below and follow these steps.
Click on NEW member -
install the activeX control - you will now have 2 choices A. Create a account B. Do not create an account. - choose Do not create an account (Unless you want to catalog your test history) -
Then click Let's Go - the next screen has a popup box that says, it is about to gather some info (the info it is gathering is for checking what is running in your background, so you will know at the end of the tests) - click OK.
That is it, it will take about 3 minutes to run the tests.
At the end of the tests it will ask 2 questions, you DO NOT have to answer them (leave them at unknown if you want).
The 2 questions are.
This computer is used at: (and the dropdown box starts with - unknown)
Connected to the Internet via: (and the dropdown box starts with - unknown)
At the end of the test, it will tell you:
(a) Internet and if you have any security flaws (and will give very easy to follow advice on how to fix)
(b) your cpu speed and compare to other testers
(c) gpu score and how well your video scores to other testers
(d) memory speeds & amount of memory, as well a comparison
(e) internet speeeds, and hints on faster internet (if needed)
(f) Disk drive performance and usage.
(g) etc...
At the bottom right click on MY SCORE. But make sure you go back and click on the flags, and it will bring you to the exact info.
The more usefull flags is Windows & Internet (it will show all the running processes)
The color of the flags are all explained, hopefully you do not have any red flags.
So how well do you compare?
Have fun....
Link -
http://www.pcpitstop.com/pcpitstop/default.asp
With luck, you get all checkered flags. Like so (see 1st pic)
My score (second pic)
