cheap RCA cables which ones.
Tommmmy
Hi,
I'm looking for good cheap RCA cables 12' to 16''
Its for my car stereo. I dont know which names brands I should be looking at.
Any tips will help a lot.
Thanks.
Tommmmy said:
Hi,
Thanks.
A few places you should check out:
Target, WalMart, Radio Shack, local electronics store, on line at www.partse-xpress.com Just remove the dash as the filter here will delete it without it:eek:
Hi Ho
Hi Ho
Get some RG-6 cable and some RCA terminations. You will have cheap, excellent quality cable.
jaxvon
jaxvon
You might also try KnuKonceptz. Some of their RCAs have a signal cable built in so you can send an "ON" signal to your amp.
PE carries a variety of RCAs and lines that are specific to car audio that are flexible and use thinner jacketing to make it easier to run in a car. I'll third them. I've bought a lot of stuff from them and been happy with the products and service so far.
